nicola.jones-2692 Posted October 5, 2021 Share Posted October 5, 2021 My truck has done just over 10000 miles and it’s in the garage YET AGAIN!! first time when it had done 5000 miles second time with the dpf failure it also says that the oil needs changing ( when the garage said that it was changed when it was in the garage for the first time anyone else have this problem? Quote Link to comment Share on other sites More sharing options...
Trevor Posted October 7, 2021 Share Posted October 7, 2021 5000 miles for an oil change on a diesel engine is about right. The DPF should be given a long run to clear it through otherwise the oil can degrade with the DPF being blocked so worth getting it changed as soon as possible Quote Link to comment Share on other sites More sharing options...
