Twinkle007 Posted October 16, 2021 Share Posted October 16, 2021 Hi all I'm new to this club and really hoping someone can assist me. I recently replaced the battery on my 2013 J10 Qashqai, I've now got the Stop/Start system fault message continually displayed on the dashboard. The stop/start function is obviously not functioning either, but other than that the car is driving fine. I have taken the car back to the garage that fitted the battery, they confirmed they updated the system to 'register' a new battery had been fitted. They used their diagnostic machine and confirmed there was no faults showing. I've also taken the car to another garage who have run their diagnostic checks and again they could not find any faults on the system. Nissan main dealer have said they could sort it, but would be upwards of £100 and can't book me in for over 1 month! I've researched on multiple forums who've mentioned a faulty clutch switch or wiring issue? Is there any way of fixing the problem outside of the main dealer? Thanks in advance for any help Link to comment Share on other sites More sharing options...
Trevor Posted October 25, 2021 Share Posted October 25, 2021 Hi .... welcome to the Club I wonder if the battery condition coding went according to plan as this seems the most obvious cause considering you had just recently replaced the battery. I would be tempted to take it back to the first garage who coded it and see if they could just determine the state of charge registered in the ECM. Otherwise, if it is correct then you should be able to initiate the stop/start as per the owners manual instructions Link to comment Share on other sites More sharing options...
Badd bazz Posted January 5, 2022 Share Posted January 5, 2022 Was the battery the correct ampage and also an agm one you fitted are there any dash light warning showing apart from stop start ? Link to comment Share on other sites More sharing options...
