Tom35 Posted January 15, 2022 Posted January 15, 2022 Oil pressure light comes on when engine is hot and but goes on and off when reving
Trevor Posted February 2, 2022 Posted February 2, 2022 I would definitely get an oil and filter change as soon as possible to start with
Tom35 Posted February 2, 2022 Author Posted February 2, 2022 Already done the oil and filter and also changed the pressure switch
Trevor Posted February 2, 2022 Posted February 2, 2022 Only other thing I can think of is an engine flush and the oil refreshing once more. A garage should be able to take readings of the oil pressure to determine if it is up to scratch, if not then flush the engine.
Register a new accountSign in
