Baleegh Posted January 27, 2022 Share Posted January 27, 2022 I recently change cam belt in Nissan Qashqai +2 1.5 dci , I asked in Nissan garage for replacement of water pump, they recommend we don’t need to change water pump as you change cam belt at the same time but if there is issue later, you can change it….. I came to know if cambelt running water pump, it’s better to change it, I still don’t know if cambelt running water pump in Nissan Qashqai….?? I need your help in this matter, Thanks Regards Link to comment Share on other sites More sharing options...
NissanFan Posted March 30, 2022 Share Posted March 30, 2022 You should ideally change both at same time given they’re both the same age and done the same mileage. 1 Link to comment Share on other sites More sharing options...
