I have a possible fuel temperature sensor problem.
Is this a separate replace-able item or part of the fuel tank or fuel pump assembly ? Thank you.
Hi
Hopefully it can be repaired or replaced as a separate item, if not and I need a new fuel pump assembly what does that run?
