littleshaz72 Posted May 15, 2022 Share Posted May 15, 2022 Aa recovered my car & took it to local garage as car wouldn't fire up without a tiny bit easy start or slight movement to bump start a week on & the garage rang me & said it's going to cost £2500 as the pump & injectors are needing replaced so I have decided against getting the work done as the car isn't worth that so I told him I would pick the car up & he said the car no longer starts which is strange as car was running fine only thing that wasn't fine was getting it to fire up I've spoke to a few people & they've said no way pump or injectors were gone as car wouldn't of started or would of been back firing & alerts so any advice on this would be good Quote Link to comment Share on other sites More sharing options...
Trevor Posted May 16, 2022 Share Posted May 16, 2022 It sounds like it could have been misfuelled but would definitely take to another garage to diagnose it further. Even with a misfuel it could clear and run well if the fuel filter is changed and topped up with correct fuel. Also, you mention it needs a bump start then maybe the battery needs replacing which could also lead to the symptoms you describe. I would definitely get the car taken back to your house or another garage Quote Link to comment Share on other sites More sharing options...
