Micra 1240cc petrol gear issue
Kevin Nicolson
Looking for help with a 2007 micra
Spirita 1240cc petrol
issue is getting the gears to change. When at standstill they work just fine and also when moving slowly , the issue getting the gear to go in gets worse the faster you go ?! Does the same if car is hot or cold , gears just struggle to change , initial thought was clutch but odd it’s worse when you get faster ?
thoughts ?
thank you
Maybe look at the engine mountings as if they are under load it could be pulling the engine over slightly too much which could affect the gear selection (only a thought)
Otherwise may be worth changing the gearbox oil to see if that makes a difference
