arcon5 Posted August 29, 2022 Share Posted August 29, 2022 Re: 1.5 DCI 2007 qashqai I'm looking for front subframe and reading somewhere they are different for the dpf and non-dpf models.... is that right? I see the dpf model has a bracket at the rear (presumably a mount bracket for the exhaust system)... So if they are different, is it just the bracket or is there a fundamental difference? Or can they be interchanged? Ie a dpf one fitted to the earlier non dpf? Link to comment Share on other sites More sharing options...
Trevor Posted September 12, 2022 Share Posted September 12, 2022 You could probably use the DPF one on the non-DPF vehicle if it is just the bracket and if it gets in the way then remove it I guess Link to comment Share on other sites More sharing options...
