Hi,
I own a Qashqai 2014 1.2 petrol model. Yesterday, when I was driving home from work, I did a slow, sharp turn left and the car swerved and stopped. I thought I had hit something, but when I checked, there was nothing on the road. An hour later, after restarting the car, the chassis control fault light came on.
I am not sure if something failed and made me swerve like that. I have booked the car in at Nissan to check, but that’s next week. Is the car still safe to drive? What could the problem be?
Thanks.
  • 2 weeks later...
Could be an ABS issue?  Let us know how it goes as interested to see what the fault is
I must’ve hit the kerb hard and knocked the back wheel out of place. Kwik Fit re-aligned the wheel and the message has disappeared. I will book it in at Nissan to check, because the wheel isn’t fully straight.
  • Like 1
  • 3 weeks later...
I had to replace the rear subframe which cost £700, but now the brake pedal feels spongy and very weak.
That is not right if the brakes are spongy and should be returned to rectify the fault
