Swerve Posted September 24, 2022 Posted September 24, 2022 How easy & what is required to remove radiator from pixo?
Trevor Posted October 5, 2022 Posted October 5, 2022 Like any radiator, you would need to drain and recover the coolant (which could be reused if the antifreeze strength is sufficient. Removal is then just a case of remove and refit components and then ensure there is no air trapped in the cooling system by running up and observing the temperature (hopefully the fan will kick in as well) and also check the heater blows hot
Register a new accountSign in
