Startup Noise
everson
That sounds like the starter motor
Probably go on forever but have heard this sound many times before and sounds like the pinion gear is dry and slow in returning when the engine starts
Hello Trevor,
Thanks for getting back andsharing some thoughts.  Moving forward, you state probably go on forever. You mean that the starter will still work but will have this noise to contend with? In regards to getting it fixed how long or what should I be looking out for , before I go "Ok, time to get this sorted now " .
Thanks 😁
55 minutes ago, Trevor said:
Thanks for this pal put mind at ease. You wouldn't happen to know of any write ups on replacing the starter or any other nissans that have the same layout / engine to have a look at?
  • Like 1
Its a case of undoing the nuts and bolts and reverse to fit, however, ensure you disconnect the battery negative terminal before starting work
