kevin underhill Posted April 25, 2023 Share Posted April 25, 2023 Hi I have noticed at low revs when pulling away a squeal, garage have replaced a belt tensioner and are now saying it could be the air conditioning pump but if I have the cvt transmission in neutral or park and gently rev the engine there is no noise.? car as done 40k and drives perfectly Any thoughts? Thanks Quote Link to comment Share on other sites More sharing options...
Trevor Posted April 26, 2023 Share Posted April 26, 2023 I think if it was a belt it would most definitely squeal on start up Belt tensioners can also cause this sort of noise but most generally a squealing belt is down to the make (or most importantly where it is made) and doesn't contain much rubber content, more of a synthetic silicon material which will squeal and stretch no matter how much you tighten it over time Quote Link to comment Share on other sites More sharing options...
