Key fob Problem
2011  Micra K13
problem with fob needing to be pressed twice to open all doors and boot
Car used to open with one press to open and one press to close all doors
any help apricated
Thanks All Bob
Worth having the battery changed as it could be getting a bit low
Also, I believe there may be an issue with the microswitches becoming detached from the circuit board inside the fob.
If you take it into a locksmiths that can change the battery they should be able to tell you if this is the case
  • 2 months later...
