K12 lights issue?
tracer64
Hello,
I have an 06 K12 March/Micra, and it has had an issue where the small lights above the headlights (can’t find exact name) are always on regardless of the headlamp stock setting when the car is running.
The car also will start the electrics (not the engine) if the car is off but the headlights are turned on (again, while the ignition is off with no key).
This issue started after a mechanic did a service on it to fix a taillight not turning on, and also had to disconnect my radio.
Does anyone have better knowledge of March electrics that could have a possible idea what’s causing this? I live rurally so wanted to have some idea of what’s wrong before bringing into an auto electrician.
Thanks for any help
It sounds like you are referring to Daytime Running Lights (DRL) and these will come on with the ignition and headlights also
Is the correct bulb fitted in the rear lamps as this can backfeed the lighting system and cause all sorts of issues with the lights?
