blueovalbug Posted May 19, 2023 Share Posted May 19, 2023 Morning all new member here hope your all ok so my nissan quashqi indicators keep flashing when I lock it they also flash randomly when it's unlocked I had the battery replaced as the battery failed a test but it's not fixed the problem has anyone got any ideas thanks jamie Link to comment Share on other sites More sharing options...
Trevor Posted May 19, 2023 Share Posted May 19, 2023 I would look at the earth leads and connections to start with, common fault on Nissan. After that then there may be an issue with the security control module (if under the dash it could have suffered water ingress from the windscreen leaking) - look for tell tale signs of water leaking under the dash area Link to comment Share on other sites More sharing options...
blueovalbug Posted May 19, 2023 Author Share Posted May 19, 2023 Hi thanks for your reply I really thought I'd cracked it I realised that the interior light wasn't coming on when the rear passenger door was open nor did it show up as open on the dashboard so I unscrewed the switch and found the wire was broken down at the bottom near the seat anywayni joined the wire back up the interior light works as it should now and it also shows up as open on the dashboard but the lights are still flashing 1 Link to comment Share on other sites More sharing options...
Trevor Posted May 26, 2023 Share Posted May 26, 2023 Sounds like there could be more wire damage elsewhere, worth checking the other door switch wiring to be on the safe side Link to comment Share on other sites More sharing options...
blueovalbug Posted May 26, 2023 Author Share Posted May 26, 2023 Hi thanks for your reply I'm confident the other switches are ok as the interior light now comes on which ever door I open so I assume there working. 1 Link to comment Share on other sites More sharing options...
