jlsjohn Posted May 25, 2023 Posted May 25, 2023 Hi The rear window wiper on my wife's 1994 NX has stopped working. There doesn't seem to be a fuse for this - any ideas, please? Thanks
Trevor Posted May 26, 2023 Posted May 26, 2023 It would be worth checking the mechanism isn't seized first otherwise replacing a fuse would power up the circuit and either blow the fuse or cause further issues. See if there is any movement on the spindle by trying to gently rotate back and forth
jlsjohn Posted May 27, 2023 Author Posted May 27, 2023 Thanks for the reply. The mech. seems free - maybe I should put 12v direct to the wiper motor and check that its ok. The fuse panel doesn't list a fuse for the rear wiper, but it does say to check with your Nissan dealer for other fuses, so I was wondering if anyone on the forum knew whether there was one for the rear wiper.
Trevor Posted May 29, 2023 Posted May 29, 2023 I would definitely try a temporary 12 volt feed but be ready to remove it if nothing happens just in case it has a high resistance and causes an electrical fire
