hairyhaggis Posted June 4, 2023 Posted June 4, 2023 hi. does anyone know if its possible to purchase the bushes for the gearbox end of a manual transmission gear change cable
Trevor Posted June 16, 2023 Posted June 16, 2023 Think they only come with the cable but you may be able to shim them out using some compound such as liquid metal which should keep them going for a bit longer
Register a new accountSign in
