Adriano Nanni Posted June 20, 2023 Share Posted June 20, 2023 Greetings all, I am writing from Rome and I own a Primera (P12) 2.2 Di 126CV / 93kW since 2003. I have the problem of replacing the power steering tube, the original spare part is no longer sold and it seems to be very difficult to build it because I cannot find the connections. I hope someone can give me some advice. Thanks for the attention. Sincerely Quote Link to comment Share on other sites More sharing options...
Trevor Posted June 26, 2023 Share Posted June 26, 2023 I would try a hydraulic pipe/hose remanufacture that makes hoses for industrial equipment such as diggers as they can make one if you take your one in as a pattern Quote Link to comment Share on other sites More sharing options...
Adriano Nanni Posted June 27, 2023 Author Share Posted June 27, 2023 Thank you for your advise but it seems that specific components (connectors) that should be replaced cannot be found. Quote Link to comment Share on other sites More sharing options...
Trevor Posted June 29, 2023 Share Posted June 29, 2023 Not sure if these are parts that can be removed as the pipe remanufacturer can simply replace the damaged section and the connectors stay the same Alternatively, they would more than likely be able to source something or change the style of connector with a new male and female connectors Worth trying to see if it can be sorted through a local hydraulic pipe repair company.....I have used a local one to me for years and never failed yet on a particular job yet! Quote Link to comment Share on other sites More sharing options...
