Rooby_roo Posted July 28, 2023 Share Posted July 28, 2023 Hi all , I have a 1.5 dci 2014, when driving and go round a left hand bend there’s like a droning noise coming from the front drivers side wheel, I changed the wheel Bearing but the noise is still there , what else could it be ? Link to comment Share on other sites More sharing options...
Trevor Posted July 31, 2023 Share Posted July 31, 2023 I would have said wheel bearing but if it has been replaced then obviously not Did the hub flange look worn? as had to replace a hub along with a new bearing after replacing it previously as horribly worn and still creating a noise Link to comment Share on other sites More sharing options...
Rooby_roo Posted August 1, 2023 Author Share Posted August 1, 2023 On 7/31/2023 at 3:53 PM, Trevor said: I would have said wheel bearing but if it has been replaced then obviously not Did the hub flange look worn? as had to replace a hub along with a new bearing after replacing it previously as horribly worn and still creating a noise The wheel bearing is the hub ? Do you have a pic of what you mean please ? Link to comment Share on other sites More sharing options...
Trevor Posted August 7, 2023 Share Posted August 7, 2023 The wheel bearing should fit into the hub assembly and the flange goes into the middle of the wheel bearing If the flange is worn (as in wear tracks on the outer surface then this has been known to cause slack between the bearing even when torqued down. The metal is a lot softer than the wheel bearing casing which is hardened steel so can wear prematurely - had it happen on my X-Trail and bought a secondhand hub assembly and new bearing to sort it Link to comment Share on other sites More sharing options...
