DavidPz Posted August 4, 2023 Share Posted August 4, 2023 Greetings All, I've a Spanish built model here in South Africa which I'm considering exporting to Portugal. Apart from needing headlight assemblies that dip to the right, it also needs a rear foglight to conform. The SA spec is clear reversing lights on both rear light clusters. Am I correct in assuming the wiring loom is 'universal' & if I get a set of EU rear clusters, it's just a question of fitting & possibly adding a relay into circuit to get a rear fog functioning on the LHS with the clear reversing light on the RHS? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Trevor Posted August 7, 2023 Share Posted August 7, 2023 You could always use a red bulb (you can get paint for bulbs) and this can be wired up in one of the reverse lights Quote Link to comment Share on other sites More sharing options...
