Acenta 2008 , drivers door opening latch as stuck open and will not go back in so can not open door from in side door will open fine from out side with the handle lever so need to put window down to open it then any answers on this cheersĀ
You'll need to remove the door card to see what has dropped off.
More than likely a linkage has become detached
