Rilo69 Posted December 16, 2023 Share Posted December 16, 2023 Hi all I have a 2012 d40 which has no switch to disable the passenger airbag. Is there a kit you can fit, or anywhere I can get a switch/isolator fitted? Thanks Steve Quote Link to comment Share on other sites More sharing options...
Trevor Posted December 19, 2023 Share Posted December 19, 2023 With the ignition switched OFF, insert the ignition key into the front passenger airbag switch, located in the glove box. Press the key and turn it to the OFF position. or also mentions that there is a switch on the passenger end of the dashboard which can be viewed with the door open Quote Link to comment Share on other sites More sharing options...
Rilo69 Posted December 20, 2023 Author Share Posted December 20, 2023 On 12/19/2023 at 10:52 AM, Trevor said: With the ignition switched OFF, insert the ignition key into the front passenger airbag switch, located in the glove box. Press the key and turn it to the OFF position. or also mentions that there is a switch on the passenger end of the dashboard which can be viewed with the door open Hi thanks for the reply, but my model doesn't have a airbag switch fitted at all. Doesn't even have a pressure sensor in the seat. I may have to get in touch with a nissan dealer and see if they can fit one Quote Link to comment Share on other sites More sharing options...
