Louise Posted January 16, 2024 Posted January 16, 2024 Hi I purchased a Qashqai 2017 a year ago. It is still under warranty. The red airbag light comes on every time there is a frost. The garage have suggested its because the battery dips in power when there is a frost. Although 4 months ago I had to have a new battery when it was flat. It now needs a mot, obviously it will fail with the light on again. It costs £100 to clear the fault. Any advice greatly appreciated.
Trevor Posted January 25, 2024 Posted January 25, 2024 Sounds more like a connector to the seat belt pretensioners under the seat. Try moving the seat to a different position with the ignition off and then switch the ignition on to see if it has cleared. If so the its the connectors under the seat
