scot the sniper Posted June 25, 2024 Posted June 25, 2024 My tub on the back is starting to rot just on both sides near the cab is there panels you can buy for this or is it a new tub. Thx scot
Trevor Posted June 26, 2024 Posted June 26, 2024 I would be tempted to remove the tub and also check the chassis for corrosion (common issue) while you are there.
scot the sniper Posted June 26, 2024 Author Posted June 26, 2024 How hard is it to remove the tub never done one but Ave worked on many cars and jeeps for many years and I have a ramp/lift
Trevor Posted June 26, 2024 Posted June 26, 2024 I have removed one from a Mitsubishi L200 and apart from someone to give you a hand to lift it off its just nuts and bolts really (oh and a bit of wiring to disconnect)
scot the sniper Posted June 26, 2024 Author Posted June 26, 2024 Cheers everyone will give it a go when I'm on holiday in 3 weeks for 3 weeks. Scot 1
