FRANKIEDURLEIGH Posted July 19, 2024 Posted July 19, 2024 Hi all, 2010 Nissan navara. Intermittently it was losing power after 2 thousand revs. Took it to the garage and they couldn’t find a fault, once home it continued to lose turbo/power and progressively went from every other drive, to every drive. Took it to a different garage and they said turbo was the issue. New turbo at £1200 and everything seemed fine and working correctly, it’s done about 150 miles and now the power loss has started again. only way of describing it is when on any incline it has no guts. You can put your foot flat to the floor and it feels like you hit a wall with it accelerating at 2 thousand revs and it won’t go! No pull. any ideas before I return to the garage please?
Trevor Posted July 19, 2024 Posted July 19, 2024 Sounds like it could be an intercooler (or one of the hoses/pipes) that may be holed, split or not reconnected
