July 24, 20241 yr Hi all I'm new today and just bought a 2015 juke tekna and the first thing I did was apart from checking the oil the tyre pressures but on one wheel the valve seems to be broke inside and my pressure gauge wouldn't work on it and when you see inside the valve should be like a pint which allows air to pass when it's pushed in was not there ? But are these types of valve's the same as ordinary valves when screwed out or are they special
