Mattchooster Posted August 19, 2024 Posted August 19, 2024 Hello - I have an issue with the turbo wastegate actuator connecting rod rattling. Can be heard when coming off the throttle. Is this a common issue with the K14 1.0l petrol turbo? I see that aftermarket anti-rattle clips can be used to press the rod to the actuator arm - do these work and does anybody have a supplier recommendation? Is the rattle a sign that the turbo is on its way out and a refurbishment required? Many thanks, Matt.
