tmccar Posted September 3 Posted September 3 I recently bought a 2000 Pathfinder diesel pickup (2.5L) I drove it home and it was going ok for the first 2.5 hours, but for the last hour it started losing power and would not rev. I had to stop and when I tried to start again after a minute or so, the revs came up, and also a cloud of blue smoke from the exhaust. The same pattern repeated itself for the rest of the journey and I was relieved to get it home. What could be causing this problem?
Trevor Posted September 19 Posted September 19 I would first check the fuel filter - replace if in doubt Otherwise sounds like the turbo variable vanes are gummed up with carbon but this usually puts the engine into limphome mode accompanied by an amber engine warning lamp on the dash
tmccar Posted November 5 Author Posted November 5 Sorry for late reply. Can you tell me where the vanes are located?
Trevor Posted November 8 Posted November 8 The vanes are located inside the turbo and can be cleaned using a cleaning solution in situ https://www.ebay.co.uk/itm/292459335127?_skw=turbo+cleaner&itmmeta=01JC60BMWEXRSD20EMHAM2ZFK6&hash=item4417ef4dd7:g:wcwAAOSwvShajqeM&itmprp=enc%3AAQAJAAAA0HoV3kP08IDx%2BKZ9MfhVJKlEsMwj%2F9Rwy31LfWXY0vu7JPmLf9xI%2B%2BMMJNw2%2BBAV%2FAzGfwovr4g0y%2B3nTHJ4Prps1SHhzuT%2Ff2g2nWknOStqIPX6QYXX8mYiOwrPQZg0rCbLgkZPxW2e%2Bb%2FYuW1DwD1hTh1Pxnmpzlv3q%2Bmbox0A19ibnfkcrcj6SmcyxcJgPmsnqSNrib3vGE5upPP8XDzI8lnokXOTc44%2FUuHtUlQmJoH0yyaUgDzXcWukxhKo4OnzBu0ua0dem9Pz9hohvhw%3D|tkp%3ABlBMUKrOrsDhZA 1
