andyjen Posted September 7, 2024 Posted September 7, 2024 My 2013 note dipped headlights are not working bulbs and fuses are fine as are all other light settings any adobe would be appreciated
Trevor Posted September 19, 2024 Posted September 19, 2024 bad earth to the headlamps possibly - check all wiring back from the bulbs and if there is a common earth point on the body panels or chassis area, then check this for damage or corrosion
Register a new accountSign in
