EllisM Posted September 12, 2024 Posted September 12, 2024 I tried to start my car this morning the normal way with the start/stop button, foot on the clutch and push the button, however, everything came on apart from the engine doesn’t come on. When pushing the button the engine doesn’t tick over but all the lights and radio come on. Has anyone had this problem before? If so what did you do to fix it? or does anyone know how to fix this problem?
Trevor Posted September 19, 2024 Posted September 19, 2024 Could be faulty battery or pedal switch Have you tried pushing the clutch down as far as it can go? Also depress brake pedal at the same time
EllisM Posted September 19, 2024 Author Posted September 19, 2024 Hi Trevor, I’ve changed the battery and tried clutch and the brake at the same time, with no luck.
