Hi can anyone please help.My brake pressure regulating valve is leaking does anyone know how to fix this.Or know where to find a replacement. Thanks Richard
I believe you could bypass it if you can't find a replacement.
Using copper pipe to take the regulator out of use.....which if you are not carrying heavy loads then it should be fine for normal use.
Quite whether it will pass an MOT I'm not too certain but if the braking efficiency is fine then it should be okay
