Nigly Posted September 21, 2024 Posted September 21, 2024 Hi all I'm Nig. I am currently experiencing climate control fan stopped working. It still lights up and I can change settings on the interface ie. I can turn it up or down and the lights show but there is no fan engaged at all no matter where I put the speed. Nothing. Now I've checked 2 fuses behind glove box but no others under bonnet altho I have located a further 2 fuse boxes and a relay box but I'm not familiar with what is working with the blower motor there. Can anyone steer me in the right direction of protocol. . Cheers in advance Nig .
Trevor Posted September 26, 2024 Posted September 26, 2024 Try gently banging the motor under the dashboard area because the motors fail when the brushes wear out and you can usually get it to turn (evenly slowly). If it does kick into life then its the motor that needs replacing
