I have a NV300 from 2018 with 145 dci engine.
Have the fault message on the display
"Check anti pollution system"
When I connect with OBD2 it says
-fault value from Nox sensor "B" -
I have changed the sensor and removed the faulty code but it still comes back. I can start the engine 3-4 times before it get back. Are there several Nox sensors or what does the "B" stand for?
Any ideas?
  • 3 weeks later...
  • Author
Thanks
Do you happened to have a link were I can purchase the "B" sensor?
I can only find one type of Nox sensor for NV300.
Maybe it is the same sensor part number if the lead is long enough to reach - that is assuming it has a B sensor.....if you do find another there, change the plugs over to the A sensor and see if the fault transfers to A sensor
