Damien Posted November 7, 2024 Posted November 7, 2024 Navara only start with easy start then runs fine, fuel pressures all perfect, fault showing for coolant temperature sensor, temp sitting at 80 degrees all the time even when u turn on ignition, fault won’t clear even when plugged out still at 80 degrees
