Damien Posted November 7 Share Posted November 7 Navara only start with easy start then runs fine, fuel pressures all perfect, fault showing for coolant temperature sensor, temp sitting at 80 degrees all the time even when u turn on ignition, fault won’t clear even when plugged out still at 80 degrees Quote Link to comment Share on other sites More sharing options...
