wannaqash Posted November 13, 2024 Posted November 13, 2024 Hi All, recently bought a T32 1.6 diesel, lovely car but found one problem with the rev counter gauge. Its almost like the car forgets where 0 revs is. for example, this is my cluster with the key out right now. sometimes I can drive along and the revs are about 2k less on the display, so anything under 2k revs shows 0 revs but then if I hit 3-4k then it shows up to 2k revs on the display. verified with OBD the revs are accurate but the display is not. about 2 in 10 journeys work fine no problems, the rest either under read or over read the revs.
Trevor Posted November 27, 2024 Posted November 27, 2024 Check all earth leads and connections under the bonnet and leading from the battery down to the chassis, engine and transmission
