andrewere Posted November 20, 2024 Posted November 20, 2024 2015 Nissan nv200. Does anyone have a link to a video showing how to replace the resistor and motor? I've seen a few on youtube but I found them a little hard to follow as most are for left hand drive vehicles so I'm not sure if I have to remove the clutch pedal or not. I'm in the UK so I have a right hand drive van. Thanks.
Trevor Posted November 27, 2024 Posted November 27, 2024 Only one i could find which as you say is for LHD van but should be similar position and not too bad to change...let us know how you get on with it
Grasal Posted March 1 Posted March 1 Hi Trevor and Andrew. I hope you don't mind me jumping on you post. A friend has a nv200 French reg, left hand drive. It seems that the blower has stopped working. So far I've checked the actual motor, which is fine and the relays, again Ok. I'm convinced it's the resister which I'm trying to locate. The problem is that all the clips from youtube etc show the resister being in the place that the added clip shows. Unfortunately, this is not there on the nv200 I'm looking at. It's not that I can't see it, a problem I'm often accused of!? If you have any idea where else it may be please, please get back to me. Grasal
Register a new accountSign in
