Hello,
new user, greetings. so both my wing mirrors are having a difficult time pivoting out and in with the motor (or the motor is having a difficult time changing the mirrors from folded to out - and back again - to be exact). I did a quick google....apparently the grease can get cold/hard/sticky, and needs to be cleaned and re-greased (?). I've just phoned the local Nissan, and they'll charge £85 to have a look at it (1 hour minimum quote time). Does anyone have a youtube or a guide for getting into the motor part of the wing mirror? I've just been outside and managed to remove the outer wing mirror case and also some of the underside, but the actual motor pivot looks like it's buried inside some more plastic casing (I'm sure this "isn't deliberate" because Nissan don't want people to be able to do this themselves, and want to give the garage £85.......)
thanks in advance
