Hi. This is my first request to anyone that can help me. I have fitted an AZDOME M300 S dashcam to my nearly new Qashqai ePower. I also bought a Hard wire kit to connect it directly into the fuse box. I have run the cables to the fuse box and put the fuses into the adapters on the cables, but I am not sure which fuse sockets to plug them into. One cable goes to a fuse that only has power when the car is on and the other goes to a fuse that has constant power. This second one is so motion can be detected when the car is parked with the ignition off. I also know that the fuse holder on the cable has to go a centain way round in the fuse socket regarding the 'Live' side of the fuse. The fuses are 10amp. There is a third wire which is for an earth. This I have connected to a bolt near the fuse box. Can anyone help me please as my car dealer will not do it as they did not supply the unit. I have a diagram of the fuse box layout, so please let me know which fuse in which row to use for each wire.
Many thanks. Baz
