PeterB Posted March 2 Posted March 2 I have a new Dec 2024 Quashqui. When using a USB stick with music files, not all the tracks are played. Some are played and some are not. There does appear to be any logical reason for this. The dealer said that the USB stick might the wrong type without explaining what type would work. After researching the various types of USB stick it appeared that what I needed was the latest USB stick termed “USB-C”. Apparently there are several types of USB sticks and the Quashqui I have needs the latest type. But this has not solved the problem, I still get some tracks that work and some are ignored. The dealer has booked the car in for them to sort the problem, but it won’t be until mid April, 6 weeks away. Has anyone else had a similar experience?
Paul480 Posted Monday at 09:16 PM Posted Monday at 09:16 PM If some of the files play, can't see it being the usb stick. Shove it in a laptop, and see wot format the files are. If some are mp3 and some flac it may not play the flac ones. That's were I would begin. Failing that just Bluetooth from phone
PeterB Posted Monday at 11:15 PM Author Posted Monday at 11:15 PM Hi Paul, thanks for reply. the files are mp3, so should all play. I am using a one of the newer sticks, USB-C, in case older sticks don’t work on the latest latest players. So everything is compatible. i will up date this saga after the visit to the dealer who is going to check player in the car.
