bultenkarlsson Posted 20 hours ago Posted 20 hours ago Hey everyone, new member here. I have a 2009 J10 Qashqai, left hand drive, with a reverse camera. My problem is that the right reverse light isn't working, as well as the reverse camera. The left light is working. When putting the gear into R the display goes black, and with that one light also coming on, I assume the car "knows" it's in R. I've replaced the right side bulb but no luck. I haven't checked the fuses yet, but I doubt that could be the issue as one light still works. I suspect that the camera draws its power from the right light somehow. That they're on the same wire and that it might be cut/broken somewhere. I'm not confident enough to rip out the interior panels to check the whole length of the cable. That would be a job for my mechanic (€140 diagnostic fee!). Does anyone have experience of any similar situation? Since the left light works, could the problem be located in the back door? Assuming it's wired like camera -> right light -> left light -> through the rubber tube thing out of the door hinge. Thank you!
