Recently purchased a NV200 and I have driven it for roughly 170 Miles. I had some dash light come on and my change gear notification light kept flashing. The van then goes into limp mode, I reset the codes and didn't happen again. This happened at roughly 160 Miles and then again at roughly 165 Miles.
Here are the fault codes...Can anyone help if its an easy fix I can do?
Basic OBD2: P1453 (Pending) (Confirmed) - Manufacturer-specific code
Freeze frame
    Calculated load: 65.1 %
    Coolant temperature: 77 °C
    Intake manifold pressure: 31 PSI
    Engine rpm: 2900 RPM
    Vehicle speed: 71.5 mph
    Intake air temperature: 27 °C
    Air mass value: 79.28 g/s
    Fuel rail pressure: 15011 PSI
    Distance driven since diagnostic trouble code cleared: 18.6 miles
Engine: P1453 - Diesel Particulate Filter Differential Pressure Control Function: Performance or Incorrect Operation
ABS: C1130 - ENGINE SIGNAL 1
Thanks
Dan
  • 2 weeks later...
possibly the DPF trying to regenerate but something is stopping the process - check all necessary conditions with the process (e.g. fuel tank of fuel, higher RPM for set period, etc)
